Home > Technical > Failed prop shaft |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I wonder if the clutch centre would have admitted the real cause of the problem after dropping the box Kev
Wed Apr 03 2019 1:30pm |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 |
No, more likely the propshaft was damaged when the box was dropped out.
Wed Apr 03 2019 2:08pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4752 |
so yours saying the they dropped the gearbox and transfer box out as one unit ? |
Wed Apr 03 2019 4:09pm |
I've no idea what they other garage did when they changed the clutch. I know if we do a clutch, we drop the lot as one. If we're removing an automatic, then we take the transfer box off first.
Thu Apr 04 2019 6:49am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4816 |
Got a feeling Kev was referring to the Clutch Centre that did the job. Cheers Col |
Thu Apr 04 2019 7:22am |
My bad! Yes, Kev was indeed referring to the Clutch Centre, not the centre plate... duh....
Thu Apr 04 2019 7:32am |
No problem Joe. I must admit I was a little confused with the reply Kev
Thu Apr 04 2019 12:43pm |
