Home > General > spare wheel issue |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
A 21" should fit as I have a 22" in mine,,is their something under the space saver that's stopping if fitting to the bottom of the well.? Andy.
Mon Apr 01 2019 7:55am |
keith277 Member Since: 31 Mar 2019 Location: North West Posts: 4 |
Hi thanks for the reply, and yes there’s a small dome shaped insert there but I cannot see how it removes, I’ll maybe have to ask my local RR garage
Mon Apr 01 2019 7:57am |
The small dome thing is the compressor for the air suspension,,the spare sits over it. Andy.
Mon Apr 01 2019 7:59am |
Ok thanks in that case I can’t see anything that’s obstructing it, the 21 inch extends out around 2 inches above the well in the boot.. I’ll take a couple of pics shortly and add them to this thread
Mon Apr 01 2019 8:17am |
This is a pic of mine
Mon Apr 01 2019 9:01am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
I think you need to post up some comparison measurements like wheel width of new wheel, width of space saver, depth of well for spare etc. Did the spacesaver sit flush with the floor? If it did then I’d say it was a space saver for that reason. In other cars if you have a full size wheel, there are packing pieces to raise the level of the floor to match that of the wheel. That obviously won’t work on a vehicle like the RRS but that’s how other manufacturers do it. 2012 5.0 SC AB
Mon Apr 01 2019 9:12am |
Thanks Andy.. just realiesd that I had not removed the polystyrene liner
Mon Apr 01 2019 9:26am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
I think you may find there are two different liners listed one for space saver spare and one for full size spare as they act as a insulator.
Mon Apr 01 2019 9:35am |
That's your problem then. Andy.
Mon Apr 01 2019 9:59am |
