Home > Technical > Level sensor issue |
I always thought when replacing a height sensor you should recalibrate the height again, probably what the issue is i would say 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sat Mar 30 2019 5:36pm |
sid1968 Member Since: 16 Aug 2015 Location: lancashire Posts: 12 |
If it needs re claribratin would a suspension fault show?? Even if it looks level visually
Sat Mar 30 2019 6:08pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
Or it could have been a sensor wiring fault in the first place. |
Sat Mar 30 2019 7:07pm |
But the original sensor was not throwin any faults?? |
Sat Mar 30 2019 7:32pm |
Completely broken an intermittent wire ? |
Sat Mar 30 2019 7:42pm |
Does it need re clarabatin on a sensor fit??
Sat Mar 30 2019 7:46pm |
It requires calibration but shouldn’t be so bad it puts the light on.
Sat Mar 30 2019 8:02pm |
