Home > Faults & Fixes > Overboosting Turbos.
winston wolf
Hello people, am new here so please be gentle, have a 2007 RRS 3.6td and had the turbos replaced, the garage says its now overboosting due to a crack in the nearside exhaust manifold.
My questions are,
Is the garage correct with there assumptions,
Are there any other possible causes to the overboosting,
It has been remapped, both egr valves removed and blanked off and Ecu delete.
Thanks in advance.
Post #577967 Wed Mar 27 2019 5:05pm
Disco_Mikey
A crack in the exhaust manifold would cause an underboost fault...
Were the turbos new or reconditioned?
How long ago were they fitted?
Was the fault present before the remap?
Post #577989 Wed Mar 27 2019 9:18pm
winston wolf
The Turbos were replaced about 4 weeks ago. The garage that replaced them said it was also going into limp mode because of the overboosting. It wasnt going into limp mode before they were replaced. They were recondictioned ones fitted at Best Turbos in Birmingham. The remap and Egr delete was done by previous owner.
Post #577990 Wed Mar 27 2019 9:24pm
Disco_Mikey
I suspect the recon turbos are the issue. The electronic actuators cannot be calibrated correctly, other than by the manufacturer. Ideally, you need to check the actual position v commanded positions on the actuators
And this is the very reason why we only fit brand new OEM turbos Thumbs Up
Post #577994 Wed Mar 27 2019 10:05pm
OvalAutos
Maybe try Midland Turbos. They do all our turbos (TDV6 and TDV8) and can set the actuator correctly to factory settings. Never had any problems with them and never had to set the actuator once fitted to the car.
Give Nathan a call to discuss the issue you're having. Good chap. Joe
Post #578027 Thu Mar 28 2019 11:36am
winston wolf
Many thanks to you both for your imputs.
There are 3 options i could go for here:-
1. Have them set by midland turbos.
2. Have a main dealer set them up.
3. Get rid of the RR. As i believe it will cause me alot of trouble further down the line.
Post #578030 Thu Mar 28 2019 11:58am
