Josh
Ah yes the air bag MY08 RRS TDV8 HSE, Stornoway Grey, Ebony and Zabrano, sunroof, hybrid tv, premium ICE, rear E diff, privacy glass, side steps, mud flaps, S/Grey mirror covers, Venture shield,tasmods, smoked indicators, Larini sports exhaust, etc, etc.
Mon Mar 12 2007 8:29pm |
Brian Mason
Very Annoyed wrote:Ian.Richardson wrote:Just had a call from the dealer. This car is coming in on the 20th March, so I expect to be able to pick up on the 24th.
In addition to all above I have also had Balck and silver badges added all round apart from the steering wheel which I was told cant be done.
You can do a bodge job! Just get one of the wheel centre caps, remove the 'LR' logo. Then drill a small hole in the logo on the steering wheel, put a screw in and just some pliers to lever off the badge. After the badge is removed get the black badge, but some double sided sticky pads on the back and put in place.
Yep, as aljo says, be careful with the steering wheel airbag enclosure Ian. However, I did mine the same method as VA and had no problems whatsoever, done in 5 minutes. Small drilled pilot hole penetrates the green tin badge really quickly so dont press too hard! Self-tapper grips the old badge, pull firmly with pliers, badge will ease out slowly. Double-sided sticky pads (or glue) fixes the new badge on the centre space. Easy-peasy! Good Luck! Never Knowingly Offensive.., so P155 OFF!!!
_________________________________________
Mon Mar 12 2007 9:37pm |
