Home > Maintenance & Modifications > JLR dignostics.... compare to IID |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
Has anyone access to or knowledge of such?
Fri Mar 15 2019 12:18pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
Programming subscriptions are required for any form of programming
Fri Mar 15 2019 12:50pm |
And it won't cover up to 2018MY, will only do upto 16MY, as anything afterwards reqs Pathfinder |
Fri Mar 15 2019 12:51pm |
I has SSD and found it a right pain then bought an IDD so much easier and safer to use.You will not end up with a 2.5 tonne paper weight as you may with SDD |
Fri Mar 15 2019 3:12pm |
I have both, IID is very handy. SDD is good for everything else. I paid £50 for SDD with a log in but today it hasn’t worked, the log in screen has changed in the last update. I’ve emailed the seller for an updated password. 2012 5.0 SC AB
Fri Mar 15 2019 8:04pm |
Seller true to his word has sorted it all out and SDD is working again. 2012 5.0 SC AB
Sat Mar 16 2019 11:14am |
