Home > Maintenance & Modifications > Standard Height values |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8833 |
462mm measured vertically from centre of half shaft (wheel) to edge of the wheelarch. 2012 SDV6 - it's missing a couple of cylinders
Mon Mar 11 2019 7:14pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
Mon Mar 11 2019 9:50pm |
That's different to the workshop manual Col. Which is not surprising when one considers this is Land Rover we're talking about. 2012 SDV6 - it's missing a couple of cylinders
Mon Mar 11 2019 10:50pm |
Not sure where I got that document from Wayne, thought I downloaded it off Topix, same dimension as Gap list in their manual, but you are right with L/R they do complicate and contradict themselves quite a bit.
Mon Mar 11 2019 11:05pm |
Superb, thanks gents 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Tue Mar 12 2019 7:46am |
http://www.disco4.com/wiki/IIDTool_Calibration_Values In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Tue Mar 12 2019 10:01am |
All of the figures quoted are within a few mm and definitely within the in-use operating tolerance of the suspension system anyway so which you choose is probably not that important. 2012 SDV6 - it's missing a couple of cylinders
Tue Mar 12 2019 11:19am |
