Home > Wheels & Tyres > Wheel bolts from 20" to 19" ? |
airc909 Member Since: 28 May 2018 Location: Coventry Posts: 112 |
hi i have standard 20" alloys from the 2005 sport
Wed Mar 06 2019 10:36am |
so here is a sport my age with those wheels fitted so guessing they must by same stud pattern
Wed Mar 06 2019 10:39am |
any idea on the bolts mate |
Wed Mar 06 2019 11:03am |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Should be the same,,sometimes aftermarket alloys have different nuts. Andy.
Wed Mar 06 2019 11:10am |
ok so these are definitely 5x120 so that is ok
Wed Mar 06 2019 11:26am |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi,
Wed Mar 06 2019 1:28pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
If the wheels are off a Fullfat Vouge prior to 2004 you will need the Fullfat wheel nuts as the shank of the nut is a different diameter to the Sport and the Sport one will not go through the rim if I remember correctly.
Thu Mar 07 2019 4:26am |
Col - thanks mate. |
Thu Mar 07 2019 10:24am |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
airc909,
Sun Oct 27 2019 10:13pm |
As Sport wheels are spigot mounted I think you may find the flat washer on genuine sport wheel nut assists clamping force the washer also tightens against the wheel face, the nut then tightens against the steel washer which in turn prevents damage to the aluminium wheel by the nut turning against it when torqued up, not sure it has anything to do with the length of the shank, the same as the taper on the end of the shank is just that a taper and makes it easier to align the stud, wheel and nut.
Mon Oct 28 2019 4:56am |
