Home > Faults & Fixes > RRS TDV8 owner after help |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
Sounds like turbos... |
Sat Mar 02 2019 9:53am |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 187 |
I would check that petrol has not been fuelled instead of diesel, my wife did that and swore blind she didn't, your symptoms sound similar |
Sat Mar 02 2019 4:21pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
Is their not an anti fuelling device built into the filler, prevents you from filling with petrol,, tried it once with mine and it closed off the filler immediately, I got about 16p worth of petrol in it.
Sat Mar 02 2019 5:44pm |
iforland Member Since: 13 Apr 2015 Location: Redditch Posts: 47 |
I'm sure the turbo has gone...the inlet hose is full of oil.
Sat Mar 02 2019 6:19pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8834 |
It can be done but is "a " apparently. 2012 SDV6 - it's missing a couple of cylinders
Sat Mar 02 2019 8:31pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
Commiserations. My SDV6 did both turbos a year ago. I remember the thread referred to but in my case/maybe for SDV6's the view was body off. So had a service and both the belts done same time. Also, while it might be possible to save a few quid using rebuilt or exchange turbos wouldn't recommend it, better to bite the bullet and fit new.
Sun Mar 03 2019 10:25am |
done some more work today, stripped the passenger wheel and took the lower inter-cooler pipe off...See the video:
Sun Mar 03 2019 5:05pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Commiserations and good luck! Kev
Sun Mar 03 2019 5:53pm |
Ok, today I managed to get the passenger side turbo off the car without removing the body...
Sat Mar 09 2019 7:52pm |
Good job. Well done. Looking forward to hearing some more good news shortly. Robin
Sun Mar 10 2019 3:14pm |
Today's work cut short by weather, but good news is that the new turbo is now back in!! It's always quicker putting stuff back together.
Sun Mar 10 2019 5:19pm |
So I've found out what happened to the old turbo.
Sun Mar 10 2019 7:17pm |
Ok, I've been a little worried about what caused this to fail in the first place so I've done some digging and I think I may have found a possible cause.
Mon Mar 11 2019 8:46pm |
A great strip down and analysis! Glad you got it sorted Kev
Tue Mar 12 2019 7:27am |
