Home > General > seat and steering moving |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
I think it is called 'Lazy Entry' and can be turned off via the menu options. |
Sun Feb 24 2019 8:19pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4853 |
Small rotary knob on l/h side of steering column below indicator stalk, probably on auto setting just turn to off position, if same as facelift variant can't really remember if same on the pre-facelift.
Sun Feb 24 2019 8:57pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 461 |
Hi, On the right hand side of the steering column you’ll find a small control stick (it moves the column up/down & in/out). If you twist it from the Auto position, it stops the seat/column moving. You could always RTFM as well. Scrumps Somerset - Where the apples do grow and the cider do flow! 2021 Defender 90 D250 HSE in Tasman with white roof. 24MY D300 AB - Verasine Blue - 😀 19MY SDV6 AB - Byron Blue - Gone 17MY D5 SDV6 HSE - Firenze Red - Gone 16MY SDV6 AB -Aruba Silver - Gone 13.5MY SDV6 "HSE Black" - Baltic Blue - Gone 10MY TDV8 HSE Galway Green - Gone 14MY D4 HSE in Scotia Grey - Gone 05 TD5 D90 CSW in Cairns Blue |
Sun Feb 24 2019 8:58pm |
johnrambo Member Since: 30 Jan 2019 Location: scotland Posts: 27 |
thanks
Mon Feb 25 2019 1:10pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
read the flipping manual
Mon Feb 25 2019 1:46pm |
Mon Feb 25 2019 4:08pm |
