Home > General > Erratic engine temp readings |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Bump.. |
Wed Mar 06 2019 10:45pm |
Sounds like your viscous van is running when it should not be |
Wed Mar 06 2019 10:59pm |
All this agro started after it had a new alternator fitted. Low and behold the fan had to come off to replace it..
Wed Mar 06 2019 11:12pm |
Usually because there to be honest they lock up so then they can be on all the time you need to see if it’s free when it’s up to temp they should only really come on when first started and yes they are mechanical as far as I am aware :thumbsup |
Wed Mar 06 2019 11:32pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
They are mechanically driven, but can increase speed by electric command. (if they are like the diesel)
Thu Mar 07 2019 1:33pm |
I've just had a look. It's plugged in and I can't see anything untoward. The engine is cold and I can spin the fan by hand but it won't spin freely if you know what I mean.
Thu Mar 07 2019 2:53pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
The viscous fan is exactly that; Viscous. It is mechanically driven to the shaft, but fluid and heat then have an effect on how 'locked up' it is.
Thu Mar 07 2019 3:19pm |
It doesn't have any aircon fans only the viscous.
Thu Mar 07 2019 4:35pm |
Dont think the tool would be able to warm the fluid up enough to lock the viscous unless as i suspect your unit is faulty |
Thu Mar 07 2019 7:02pm |
There are some electrics that can bypass the vicious or something. |
Thu Mar 07 2019 7:39pm |
This may be a coincidence but today I drove it without the LPG on as I had ran out and guess what - normal operation..
Sun Mar 10 2019 4:41pm |
Dont get what you have when i run mine on lpg but you never know do you know who fitted the system to your car |
Sun Mar 10 2019 6:36pm |
No, it was on it when I bought it. Its a proper job - BRC kit with auto valve lube etc. |
Mon Mar 11 2019 6:45am |
I'm not sure it's the fan. Yesterday I used it a drove 1.5 miles, stopped at some traffic lights and the temp gauge suddenly started dropping fromm half to 1/4 all in about 5 seconds.
Fri Mar 15 2019 7:24am |
