Home > General > Sat Nav - Y??? |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1738 |
Trying to remember the sat nav, but are there not three options once the route is calculated?
Sat Feb 02 2019 7:29pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Its not the greatest SatNav, well certainly the version I have in my pre-facelift. I've had the same issue where it prefers a more major road over a b-road shortcut that stops 10 miles on the journey. Either that or random deviations when on small roads. I always run in a view level that I can see these strange routes then take view and over ride when I think its being stupid.
Sat Feb 02 2019 8:27pm |
Also the satnav in my 2007 RRS could be set to learn routes you use that it wouldn’t normally take you down, so next time you drive the route in good weather set the satnav to learn mode. My L494 also had the facility - the first time I drove from home into Glasgow it routed me cross country through all the local villages whereas I take a route that,while 7 miles longer,has no speed restricted villages and is on a flatter, less twisty road which actually saves some 10 minutes despite its additional distance. The L494 never routed me through the villages again but then the alternative road I mention above that I use was closed for a long spell and the satnav had to relearn the old route and trying to get it to calculate using that old route was quite difficult so ended up driving it without guidance.
Sat Feb 02 2019 9:17pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
I have not come across any sat nav that beats Waze. |
Sun Feb 03 2019 3:11pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
how do you set a 2007 to learn?
Sun Feb 03 2019 3:56pm |
