Home > Technical > ATC (automatic temperature control) module Help!! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
The arc is the unit in the dash with the buttons on.
Sat Feb 02 2019 12:50am |
Ziguk Member Since: 01 Feb 2019 Location: Wrexham Posts: 19 |
Hi
Sat Feb 02 2019 12:59am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4835 |
This is probably what you are looking for, however you would need to verify part number based on Vin No. as per usual with L/R there are numerous choices based on the options you may have fitted to vehicle, although a lot will have superseded to same number. The picture you have posted appears to be for Facelift Variant of the RRS1 2010 on, not a 2005 year vehicle.
Sat Feb 02 2019 1:15am |
Thanks
Sat Feb 02 2019 1:31am |
Those picture are for a 2010 on vehicles, not 2005 as you say you have. I suspect you have the workshop manual for the 2010-2013 vehicles not 2005-2009.
Sat Feb 02 2019 1:44am |
Thanks I thing your right about the manual although judging by the pic of the climate controls looks like same system
Sat Feb 02 2019 2:09am |
Do to heated window switches and seats light up when pressed?
Sat Feb 02 2019 8:48am |
Hi
Sat Feb 02 2019 9:42am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Sounds like a stuck air mix flap to the passenger side, likely a motor failure. I think they are a Delphi product, so not all that reliable
Sat Feb 02 2019 9:51am |
Thanks
Sat Feb 02 2019 10:24am |
there is 1 fuse which only does that one water pump. The fuse is know to fail if the water freezes (it's below 0 ATM).
Sat Feb 02 2019 10:38am |
They all sound common faults to me and I wouldn't blame the "ECU" ATC
Sat Feb 02 2019 10:44am |
Fuse 11 behind glovebox for water pump.
Sat Feb 02 2019 10:48am |
Thanks
Sat Feb 02 2019 11:36am |
