Home > Maintenance & Modifications > 2008 - Should I replace the Air Struts? |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
100k is alot on Dampers, but the only way to test properly is to take them off the car. Once air is released and they can be extended fully and compressed, you will then have an idea of their damping effect.
Thu Jan 24 2019 10:35am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
My dampers were "fine" at 206k miles, in that they still worked as dampers are intended to do
Thu Jan 24 2019 12:08pm |
Can i ask which you went for? Damper only? Fit with new O rings etc? easy enough? 2011 MY D4 HSE
Thu Jan 24 2019 1:10pm |
GunnerBill Member Since: 24 Jan 2019 Location: Aberdeenshire Posts: 18 |
Thanks the replies. I'd be interested to know which Bilstein you went for and also where to get seal kits for the Air spring unit. |
Thu Jan 24 2019 7:56pm |
Complete OEM struts and airbags While the bags were also fine, not leaking etc, they were 13 years old. Rubber perishes with age, so it was a good time to replace them too I did look into Bilstein shocks and new bags, but don't think they warranted the extra expense... |
Thu Jan 24 2019 8:12pm |
OEM a good way to go I think, and agree with the extra expense against bonuses.
Thu Jan 24 2019 10:33pm |
