Home > Technical > Fairy Lights as DRLs L320 |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
I'm very pleased with myself and expect lots of other members have already done this mod but if not it's an easy mod to do using the LED side lights as DRLs. I'm no way technically minded when it comes to cars my mate usually changed the windscreen wiper blades over for me when I need them changing.....
Tue Jan 22 2019 5:18pm |
No I didn't. I gave up waiting for it to arriver to be honest! I had an hour to spare today, all the parts except the switch and really wanted to get it done so I thought that I may as well just get on with it... I may fit the switch at a later stage when it finally arrives?? Cheers Laurence. |
Tue Jan 22 2019 7:24pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Exactly the same as I did! I fitted the cables first, then whipped them out and put the switch in around a month or so later. Kev
Tue Jan 22 2019 7:54pm |
What an impatient lot we are on here...
Tue Jan 22 2019 8:05pm |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
Buster,
Tue Jan 22 2019 9:59pm |
Hi Jason,
Tue Jan 22 2019 11:10pm |
Thanks Buster, will give this a go as always wanted the leds as drl
Tue Jan 22 2019 11:31pm |
Looks ok but I agree that LEDs look really good, should’ve been DRLs as standard from the factory IMHO.
Wed Jan 23 2019 9:31am |
They are stuck on the front of the existing lenses, but they are right at the bottom and are black so don't really notice, they come on when ignition switched on and then go off 20 seconds after ignition turned off. I wired them from a blank ignition live fuse in engine bay.
Wed Jan 23 2019 11:53pm |
Bought the leads today so will fit over the weekend to see the results |
Thu Jan 31 2019 5:57pm |
Job done.
Fri Feb 01 2019 5:10pm |
Tomascole1 Member Since: 26 Jul 2018 Location: Gwent Posts: 104 |
What ones and how did you fit the them? (Into the lights) |
Fri Feb 01 2019 6:13pm |
I did the upgrade that Laurence (Buster007) described.
Fri Feb 01 2019 7:01pm |
How easy was it to fit halo rings inside headlights |
Sat Feb 02 2019 12:00am |
