Home > Maintenance & Modifications > Low power from Alternator? |
Panoramix Member Since: 27 Sep 2010 Location: Milan Area Posts: 33 |
Hi all.
Mon Jan 07 2019 7:57am |
The battery is brend new, Bosch S5 100Ah.
Mon Jan 07 2019 9:08am |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
With a new battery, you should be seeing a change in volts when switching the loads in and off.
Mon Jan 07 2019 12:19pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
The battery is just a bit down and the car's system is reducing the electrical load - one of the first things is low power mode in the radio, if the battery gets lower the sound of the radio will be muted.
Mon Jan 07 2019 12:41pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
I would expect to see around 14.5 V with the car at tickover and no extras running, but I would use a voltmeter direct on the battery for readings. 2010 RRS, TDV8
Mon Jan 07 2019 7:01pm |
As above, with engine running 14v plus is what you should be seeing. Be aware that a faulty Alternator can take a battery with it when it fails.
Mon Jan 07 2019 9:41pm |
The voltage in the system will only be up around 14v for a short period soon after start - when the alternator has put power back into the battery from the start the alternator will lower voltage to around 12.5-12.8v if electrical loads are normal - sounds all normal for a battery slightly down - as i said go for a good drive and all should be good. 07MY RRS TDV6
Mon Jan 07 2019 11:06pm |
One day after this post, battery light on dashboard for alternator failure
Thu Jan 24 2019 10:03am |
