Home > Maintenance & Modifications > Heater not blowing hot. 55 plate rrs |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1133 |
Hi,
Fri Jan 04 2019 6:15pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4320 |
Are both sides the same temperatures? |
Fri Jan 04 2019 8:05pm |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 |
Hi, yes both sides seem same temp. If i turn Aircon off then it definately gets warmer. DT accross the flow and return is narrow so dont think its blocked heat ex |
Fri Jan 04 2019 9:41pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
Sounds obvious, but check that your pollen filter isn't blocked. If the fan can't blow through it, then no heat !
Tue Jan 29 2019 7:23pm |
