Home > Maintenance & Modifications > Egr valve
Bfeakes
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Egr valve
Hello. My engine management light has just come on. It shows code P045C egr b control circuit low. First question is. Why side is “b” and are pattern parts any good or would you go with genuine Land Rover? The other code is P0196 with is engine oil temp sensor circuit range and performance. I take it that this is just a oil pressure switch as I call it? Thanks for any help with this.
Post #571842 Fri Dec 28 2018 11:47am
no, there is an oil temp sensor in the sump.
Quite obvious when you look
Post #571844 Fri Dec 28 2018 12:54pm
Bfeakes
Andy K. Where abouts is it please?
Post #571847 Fri Dec 28 2018 3:40pm
remove the metal undertray under the car
locate the black sump with the drain plug.
sensor is in the side of the sump
Post #571848 Fri Dec 28 2018 4:01pm
Bfeakes
Had a look. Just where you said. Thanks for that
Post #571849 Fri Dec 28 2018 4:06pm
