Home > General > Rear Seats 2011 RR Sport HSE |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Should be exactly same as single seat, small strap between base cushion and back of seat to pull and release cushion, then release back section using lever in top of seat. I'm inclined to think that the release strap for the cushion has either broken or been trapped under base when previously used. If I remember right there is a bit sewn to the base the strap should thread through so it doesn't get stuck underneath.
Wed Dec 26 2018 8:57pm |
XIII Member Since: 11 Apr 2016 Location: Radlett Posts: 37 |
Hope you found the strap and managed to fold seat and get pressies to the grandkids |
Thu Dec 27 2018 12:13am |
iwtts22 Member Since: 04 Nov 2018 Location: Gamlingay Bedfordshire Posts: 10 |
Thank you soo much
Thu Dec 27 2018 1:22am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
To ensure that the pull strap doesn't slip back out of sight, there is a small fabric guide on the back of the seat. Thread the pull strap through the guide and the pull strap will always be in the correct place. |
Fri Dec 28 2018 12:26am |
Thanks found it and threaded it through so hopefully no more problems
Fri Dec 28 2018 12:28am |
