Home > General > Cannot seem to find the cause |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1239 |
From memory I think the rear exhaust has been mentioned before. Perhaps just give that a once over.
Sun Dec 09 2018 9:15pm |
Or possibly the harmonic?? weights under the car swinging 2012 5.0 SC AB
Sun Dec 09 2018 9:18pm |
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 |
Harmonics? is this normal lol
Mon Dec 10 2018 2:33pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 866 |
Try some heavy weights in the boot. (bags of sand) & see if noise is still there or set to off road height & see if its there. May point to suspension air bags. Just a guess. |
Mon Dec 10 2018 2:43pm |
There’s 2 very heavy swinging weight at the rear to (I believe) dampen harmonic resonance in the body. These weights can knock as they swing. Someone with a better idea can explain. 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Mon Dec 10 2018 3:17pm |
If you have added any aftermarket exhaust or exhaust trims these can tap on the harmonic balance weights and the mountings, when I added chrome tail pipe trims to my TDV8 in 2007 it took an age to find that that was the cause of the metallic rattle from the near side rear. Loosened off the trim and turned it a tiny bit to clear the harmonic damper and no more rattles. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Dec 10 2018 4:08pm |
Thank for all your input, I'll bear it all in mind when I take it to Land Rover specialist after I've tested it in off road height.
Mon Dec 10 2018 5:25pm |
tried off road and the noise is still there, could that mean the airbags ? RRS TDV6 2010 |
Tue Dec 11 2018 10:08am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
I had something similar which was worse going slowly over a rough road than potholes. I had my local indy look at the bushes and they said all was well, ie it would pass an MOT. However there was a small amount of movement in the rear ARB bushes. I had them replaced (£250) and all is now quiet. |
Tue Dec 11 2018 2:24pm |
Rear arc bar was found leaking at service 3 weeks ago and had it replaced under warranty £2850 job but noise still there over humps and potholes lol RRS TDV6 2010 |
Tue Dec 11 2018 3:43pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Is your spare wheel tight or moving with a thump on the underside?
Tue Dec 11 2018 3:57pm |
Only stuff in the rear area is the break down kit but that's well fitted..
Tue Dec 11 2018 4:58pm |
