Home > General (L494) > Speedo correct? |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 184 |
All tyres fitted to an RRS are the same diameter whether on 22 inch wheels, 21s or 20s. The speedo on an RRS is about 4-5% optimistic. For instance when I see 105kph on my speedo I am actually doing 100kph. SDV8 arrived and fantastic even the infotainment!
Tue Dec 04 2018 12:55pm |
There is a 10% high margin of error permitted on uncalibrated speedos so at 70 speed limit you can be up to + 7 mph out. You can get an indication of errors using a phone app route guidance program online for your phone - one that shows your speed and you can compare the readings. Don’t use the in car nav system as it is an average not an instant reading
kmpowell Member Since: 23 Oct 2016 Location: UK Posts: 259 |
As Tim says, ff you download a GPS speedo app you will get a better picture of your actual speed. On mine 74mph is 70mph. 95mph is 89mph (tested on a private road of course). SOLD - MY16 SDV6 Autobiography Dynamic - Fire Engine Red, Fixed contrast pan roof, TV, Dual Screen, 5+2, Privacy, Noble paddles. |
Tue Dec 04 2018 1:19pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
I have a Road Angel in my car which is GPS based. At 70mph on Road Angel the RRS speedo is showing 74. I never look at the car speedo now, always Road Angel. Only downfall of Road Angel is it is not bright enough especially on a sunny day. I emailled them about it, but no reply although they are quick enough to phone you when the subscription is coming up for renewal. |
Tue Dec 04 2018 1:38pm |
00by Member Since: 25 May 2018 Location: Northants Posts: 81 |
You're right on the 10% margin of error, however it is only in one direction - your speedo can read up to 10% too high but cannot read lower than your actual speed. (Well, it obviously can technically, but not legally.) MY16 RRS 3.0 SDV6 HSE Dynamic |
Tue Dec 04 2018 3:17pm |
Cornishman Member Since: 12 Jul 2018 Location: Cornwall Posts: 27 |
Thanks for all the info, will get the app, will be interesting. |
Tue Dec 04 2018 5:49pm |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Is yours a RRS1 or 2 & what size 22’s are you running.? But as everyone says speedos are always set under the actual speed you are doing,I’m running 295/40r22’s the same as they fit on the svr’s with 22’s & mine is more accurate to the Satnav than it was with the 275’s. Andy.
Tue Dec 04 2018 6:20pm |
Sorry Tyrefitter, it’s a my16 hse 306, still running original continentals cross contact lx 275R40 x22 |
Tue Dec 04 2018 9:22pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
As far as I'm aware, the accuracy of speedometers is governed by EU directive and must not under-read, and can over-read by up to 10%. I use a sat nav, I have a Garmin, the wife used a TomTom. Give it a try and compare it to your speedo so you know where you stand.. |
Wed Dec 05 2018 10:04am |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 |
Speedometer 55 Pro is a good app for checking your speed. It also has a feature which reverses the figures and gives you a speed head up display on the windscreen if you put your phone on the dashboard.
Wed Dec 05 2018 6:09pm |
