Home > General > ENGINE SYSTEM FAULT WARNING DISPLAY |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
Removed |
Fri Nov 30 2018 6:09pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 464 |
See if there is a Terraclean company near you that cleans the EGR's & DFP,
Fri Nov 30 2018 6:17pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
I had a Terraclean done on my Jag as it was showing EGR and DPF faults, it worked great. 2016 Black SDV8 Autobiography
Fri Nov 30 2018 6:28pm |
ratty2828 Member Since: 07 Nov 2018 Location: southampton Posts: 12 |
Thanks for replies guys,took car to Terraclean garage today he said it wasn't the EGR VALVE but was the Turbo so don't know what to do now |
Fri Nov 30 2018 7:07pm |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2833 |
not sure about the TDv8 but the V6's had some issues with the Turbo actuators sticking..
Mon Dec 03 2018 12:07pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 916 |
I had issues similar to this,, you don't say what mileage is on your car though. Normally EGR valves are not so much of a problem on the V8 compared to the V6, but saying that I suffered engine light and reduced performance issues at around the 95k mls mark. Had to replace the valve in question,, one thing I will say, if you have to replace them do both. I only replaced one and a couple of mouths later the other failed,, you will save money by doing both at once. 2010 RRS, TDV8
Mon Dec 03 2018 5:09pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
My TDV8 had the EGRs changed at over 150k miles and that was only because they had to come out to allow access to do something else - may as well change them in that situation! They weren't throwing any errors up to that point.
Mon Dec 03 2018 5:19pm |
