Home > Technical > Am I missing something |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Although the RRS1 3.0L does have the possible issue on some vehicles with breaking/snapping the crankshaft, I didn't think they suffered from the oil dilution issue. However regular oil changes can never be a bad thing.
Fri Nov 30 2018 1:56am |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 465 |
So is it certain models and certain years that suffer,
Fri Nov 30 2018 2:00am |
I think it is just pot luck with the crankshaft breaking, as I believe L/R said the cured the issue with the RRS2 but obviously they haven't or at least not in earlier one's.
Fri Nov 30 2018 2:07am |
I have never heard of oil dilution on RRS 1 SDV6 or on Discovery 4s. 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Fri Nov 30 2018 7:43am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
The oil dilution problem isn't to do with cold starting, it's to do with the way the DPF is regenerated. Slightly excess fuel is injected in to the engine to "burn off" the crud in the DPF. This is fine if done now and then when the filter needs it. The problem is that so-called "partial regeneration cycles" occur where the DPF isn't cleared out and the system tries to regenerate it next time the engine is running. So the engine has quite a lot of excess fuel pumped through it over time and this dilutes the oil.
Fri Nov 30 2018 10:28am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
On some of the jap pickups they have an X stamped on the dip stick about an inch to 2 inches above the max mark. In the owners man it says to change the oil when this mark is reached
Fri Nov 30 2018 11:25am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
I know a few people blame DPF / oil dilution for cranks snapping, but
Fri Nov 30 2018 1:44pm |
