Home > General (L494) > Decided to have DMS ECU Remap |
You seem to be a lot of torques short of the 306’s 700nm even with 50 more horses under the bonnet 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Nov 21 2018 4:23pm |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 152 |
Hi Tim - I believe the DMS figures are in ft/lbs which, when converted to nm is 816nm so sounds about what you might expect...
Wed Nov 21 2018 4:31pm |
You would need to check that torque as I have read on the forum somewhere that the 306bhp operates right on the upper torque limit for the ZF gearbox in standard output of 700nm 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Nov 21 2018 4:47pm |
Tim - thanks -you may well be right - if I have the ZF 8HP70 which I reckon we all do (?) then the max torque rating is 700nm.
Wed Nov 21 2018 5:05pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
You will be lucky to see much higher than 320-325bhp. Its all good and well quoting big numbers...
Wed Nov 21 2018 5:26pm |
Thanks Disco Mikey - yes that makes sense.
Wed Nov 21 2018 5:55pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
Can definitely vouch for Alive tuning per DM. |
Wed Nov 21 2018 8:47pm |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 |
Hi Guys.
Wed Nov 21 2018 9:38pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Bear in mind that quoted torque figures are peak, as are power figures. At peak power, the engine is not generating anywhere near maximum torque. At the point the standard SDV6 is producing peak power, torque is down around 500-450Nm.
Thu Nov 22 2018 12:53am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
Maximum rated input torque figures for ZF transmissions, but sure ZF build in quite a high tolerance though. My old 5.0L S/C has the 6HP28 rated at 650Nm but for the last 3-4 years has been throwing out 750Nm thanks to Alive Tuning and it hasn't disintegrated yet. That figure was what they obtained on their Dyno.
Thu Nov 22 2018 2:15am |
So I had the remap done at the weekend.
Mon Nov 26 2018 1:41pm |
harisson Member Since: 28 Jun 2018 Location: CH Posts: 183 |
sounds interesting @Punkawallah
Mon Nov 26 2018 4:30pm |
Hi @Harisson,
Mon Nov 26 2018 5:37pm |
yes, sorry, I didn't recognize that yours is a MY14 with 292HP and 600Nm.
Mon Nov 26 2018 8:54pm |
