Home > Maintenance & Modifications > Driver side turbo replacement |
richtdv8 Member Since: 06 May 2014 Location: Rotherham Posts: 47 |
Tue Nov 13 2018 5:54pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
Didn't know you could remove the turbo on the V8 body on.
Tue Nov 13 2018 6:11pm |
Cheers Andy,
Tue Nov 13 2018 6:50pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
The driver's side turbo has the crankcase breather outlet plumbed in to its inlet pipe. The breather system has an oil separator in it (up in the V at the backend of the engine) that is supposed to remove oil but no doubt some will get through.
Tue Nov 13 2018 8:28pm |
Isnt there a mod, factory tsb fix to sort this?
Tue Nov 13 2018 9:44pm |
I thought that was for a TDV6 issue. 2012 SDV6 - it's missing a couple of cylinders
Tue Nov 13 2018 10:04pm |
Thanks for the info, I hope that is the problem as it would save me removing the turbo, which may not be poss anyway.
Tue Nov 13 2018 10:39pm |
