Home > Maintenance & Modifications > EAS front and rear strut assembly part nos. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Numbers appear to have been superseded, and go across to Complete Units with ACE and Roll Bar Stability Front LR016415 Rear LR016419
Tue Nov 13 2018 7:49am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Cheers Col,
Tue Nov 13 2018 8:45am |
Col,
Tue Nov 13 2018 9:10am |
rangemogger Member Since: 09 Nov 2010 Location: Canary Islands , Spain Posts: 45 |
Hello ,
Wed Nov 14 2018 3:42pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8841 |
No, just putting on new air suspension components will do the job and maintain the vehicle's overall ability. Coil conversion would turn the RRS in to a Nissan Xtrail... 2012 SDV6 - it's missing a couple of cylinders
Wed Nov 14 2018 6:15pm |
Not really , there are boxes than intercept the signals from the suspension module , and that way the terrain response system , hdc , tc , etc will still work https://www.roverparts.com/Parts/L319SRK-OME , https://www.roverparts.com/resources/video...e-springs/
Wed Nov 14 2018 7:36pm |
Watching the promo video for that coil kit, they talk about 2 inch lift, HDC working etc. All lovely but the air suspension gives up to 5 inches of lift when required and allows dropping to access beight for low car parks etc. A 2 inch coil gives none of that flexibility. For those needing a lift at speed (corrugations etc) kits are available to make the air stay raised at speed.
Thu Nov 15 2018 1:23am |
You are right ,IMO , about the hability to lower the car in lower parkings , but you will be wrong if you have oversized tyres . Again it´s true the 5" lift but you can´t use this lift to long and to fast , the car will lower the height , and of corse at that height the suspension will not have downtravel and very stiff ride.By the way , it seems to me that the 4.4 L320 in the installation video has four pipes along the frame rail from the ACE system https://www.roverparts.com/resources/video...sport-lr3/
Thu Nov 15 2018 5:44pm |
Thanks for all the tips and opinions
Sun Nov 18 2018 6:48am |
