Home > Technical > Power fold mirrors |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
May not be relevant after all this time, but there was a TSB/Service Action about juddering mirrors I think it involved fitting a extra washer or something like that can't really remember exactly, will see if I can find a copy, may help.
Tue Nov 06 2018 8:42pm |
bazza d Member Since: 08 Nov 2015 Location: lincoln Posts: 11 |
i had this problem about 12 months ago on mine and and used WD 40. put the thin nozzle in the swivel area gave it a good blast and cleaned off the excess and its worked perfectly ever since. |
Tue Nov 06 2018 10:29pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
WD40 is not a lubricant it is a WATER DISPERSANT, hence its name WD. It will work for a while but over time it will gum up the works by attracting cr@p to stick to it. Use a spray silicon grease or at least a spray grease.
Tue Nov 06 2018 10:47pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
A first world problem - back here in the backwoods I dont even have power fold mirrors 07MY RRS TDV6
Wed Nov 07 2018 12:58am |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
I took my mirror apart and lubricated everything with white grease . Did not really solve the problem , i think i need a new motor ... |
Wed Nov 07 2018 2:08pm |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 |
Thanks for the info I sprayed the all the moving parts on mirror with silicone spray and all working ok 👍 |
Thu Nov 08 2018 7:12pm |
