Home > Technical > Anti roll bar bushes. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
Workshop manual: http://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf 2012 SDV6 - it's missing a couple of cylinders
Mon Oct 29 2018 11:00pm |
Demaske1 Member Since: 17 Oct 2018 Location: Cheshire Posts: 26 |
thanks but that's the owners manual, not the workshop manual. thanks anyway. |
Tue Oct 30 2018 11:29am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Are you sure? thought it started with Owners Manual then went to Workshop Manual.
Tue Oct 30 2018 11:54am |
I suggest you look again. 2012 SDV6 - it's missing a couple of cylinders
Tue Oct 30 2018 5:42pm |
Sorry about that 😴 |
Tue Oct 30 2018 8:25pm |
kevin 2260 Member Since: 27 Sep 2018 Location: SHEFFIELD Posts: 8 |
Hi, mine too had a knocking, the job can be difficult if the retaining bolts don't come out, and you need various 15mm spanners because the bolts themselves are very awkward to get to, I'm somewhat handy, but I had the advantage of having a full time mechanic there that knew exactly how to do the job.
Sun Nov 25 2018 4:50pm |
mermade Member Since: 09 Jan 2019 Location: manchester Posts: 2 |
its worth upgrading to poly while you are at it https://powerflexstore.co.uk/land-rover/ra...2005-2013/ |
Wed Jan 09 2019 1:02pm |
