Home > Technical > Parking with suspension up or down. |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 465 |
I am also very new to RRS ownership,
Thu Oct 25 2018 8:46pm |
I quite often lower mine as you say i think its better to use the toys it has regularly but that's my thought also if i leave mine for a while i will put in access mode as was once told unless they are there they never fully go to sleep but i was told that but don't know if it's correct or not |
Thu Oct 25 2018 9:31pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
About the only time I use mine is when I wash it which isn't very often, down to wash roof, up to wash under wheel arches, probably tempting fate but never had a problem yet in ten years of sport ownership.
Thu Oct 25 2018 9:45pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
I rarely use access height - perhaps if an oldie needs to get in the car. Off road height has been used more to be honest.
Thu Oct 25 2018 9:51pm |
One of those things that's said but there is no evidence that it's the case, to be honest. The shut down time is determined by the various ECUs talking to each other and ensuring CCFs are stored etc. Putting it in access height doesn't change that. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Oct 25 2018 9:53pm |
I forgot to mention I do have short legs.
Thu Oct 25 2018 10:55pm |
Yours looks like it has side steps. Even with short legs surely access is simple enough? 2012 SDV6 - it's missing a couple of cylinders
Thu Oct 25 2018 10:57pm |
LOL,,I bypass that direct to the floor..
Thu Oct 25 2018 11:21pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Try to minimise the use of height settings as it willm extend the life of the compressor considerably. Unless you need to lower to get into your garage leave it at onroad height. Using it more does not make it better. 07MY RRS TDV6
Thu Oct 25 2018 11:43pm |
Maybe not but it certainly makes my battery last longer when i dont use the car so from that point it does make a difference |
Fri Oct 26 2018 3:50pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
The time taken for the car to “go to sleep,” ie drop to its lowest battery usage is determined by how you lock it. Unlocked the car will sleep after about 30 minutes, on a single lock about 20 minutes and about 12 minutes if you double lock it. The suspension position doesn’t affect these times.
Fri Oct 26 2018 4:14pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1127 |
both my wife & I are short people, so i always use Access height when parking. --
Fri Oct 26 2018 4:40pm |
The side steps are functional. Had them on my TDV8 for a period. Worked well too. I'm around 100kg (16st+) and they didn't flex when I used them. They did bend up a little when I grounded them off road once, but even then not enough to stop the door opening. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Oct 26 2018 9:35pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
I do drop it to access height. I find it easier to get in and out and I have side steps and am 6ft 1 so not a shortarse issue. Also easier for loading boot. It is designed to be used. I don't buy the "it'll wear out the compressor" argument and at 90k miles no issue. I also cycle through hi and lo range once a day and 3 or 4 times a week use it to access up a very steep drive. These things are there to use. At the end of the day it is personal choice. Using them won't break the car. Those that don't use them won't break it either. |
Sat Oct 27 2018 8:17am |
