Home > Technical > Dynamic Response system |
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 |
How do I bleed the Dynamic Response system, do I really need specialist equipment |
Tue Oct 16 2018 9:52pm |
This is the pump part to pressurise the system. The other bit is the wiring, the one I made has 2 croc clips to go on the battery and the other end split the feed to 2 connectors which fit on the valve block. One connector would work I think and you would just do the one ARB at a time (switching connections between front and rear).
Wed Oct 17 2018 7:01am |
great thanks for you help I know it couldn't be hard, just not quite sure about the valve block. seems to have 3 solenoids. do they all need to be powered up together ? |
Wed Oct 17 2018 5:27pm |
As far as I know, there’s 2 solenoids, 1 connector for each. 2012 5.0 SC AB
Wed Oct 17 2018 5:48pm |
