Home > Technical > Is it possible to reverse the adaptive cruise default? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
You can adjust the ACC with the steering wheel controls, and switch mirrors dipping in reverse off in the menu settings if I remember correctly.
Sat Oct 13 2018 10:48pm |
PompeyDave Member Since: 08 Jul 2018 Location: Portsmouth Posts: 64 |
Thanks Col, yep I know I can adjust it to the shortest distance, but I'm having to do it every time I set the cruise. It's a real pain. |
Sat Oct 13 2018 10:51pm |
Have to admit I hate the ACC and never use it, didn't realise it defaulted back to furthest distance each time it switched off.
Sat Oct 13 2018 10:57pm |
I'll check the menus for the dipping door mirror options, thanks! |
Sat Oct 13 2018 11:00pm |
I think it's in Vehicle Set Up.
Sat Oct 13 2018 11:09pm |
For mirrors, put it in reverse and then set the mirrors to where you want them for normal driving. That way they stay where you want them and they won’t change. 2012 5.0 SC AB
Sun Oct 14 2018 12:44am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8828 |
When I used adaptive cruise - which I think is fab - I found the shortest distance was akin to automated tailgating. Why would you want to sit so close to the rear of another vehicle? 2012 SDV6 - it's missing a couple of cylinders
Sun Oct 14 2018 1:15am |
Personally found it easiest just to switch mirrors off in set-up menu, few presses of the button. What I did was set them where I wanted them in reverse if I needed them, then just turned them off so can reactivate them by using menu if needed, without having to re-adjust them.
Sun Oct 14 2018 1:20am |
^^^^ Exactly I always adjust mine to furthest distance, mine defaults to one of the middle distances. If I had somebody tailgating me as close as the shortest setting I'd be slamming my brakes on to tell them to back off! 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Sun Oct 14 2018 10:55am |
Snow White Member Since: 09 Jan 2018 Location: Mid Norfolk Posts: 29 |
Mine is supposed to have adaptive cruise control, but so far I haven't found it in any of the setting.
Sun Oct 14 2018 11:02am |
Do you have the switch on the L/H the side of the steering wheel with the arrow markings on it, if not you haven't got it.
Sun Oct 14 2018 11:20am |
Ahh.
Sun Oct 14 2018 12:19pm |
Well my shortest distance is about three car lengths in front. The problem I have is that at the default maximum length I fall further and further behind the car in front as each driver pulls out in front, causing me to drop further back. Then another pulls out and so on... |
Sun Oct 14 2018 9:44pm |
Ok, I’ve adjusted the mirrors in reverse to match those settings going forward, so thanks for that little tip. One other small niggle- the sat nav voice volume is set to ‘ears bleed’ level- is there any way to turn it down rather than manually at every instruction? |
Wed Oct 17 2018 7:53pm |
