Home > For Sale & Wanted > SOLD
rickshaw
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
SOLD
Now SOLD
Post #566662 Thu Oct 11 2018 10:39am
PhilMid
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Can I have the lead please! I’ll PM you.
Thanks
Post #566667 Thu Oct 11 2018 11:00am
rickshaw
Ipod lead now sold to PhilMid
Thank you
Post #566671 Thu Oct 11 2018 11:44am
B9BS X
Do you have any pics of the headphones? And will they work on a 2010 RRS RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #566724 Thu Oct 11 2018 9:11pm
rickshaw
Hi
Photos added - all 3 pairs in identical condition
As far as I know they are compatible with a 2010 RRS. They came with my 2013 Black Edition as standard (it had the front TV fitted) but as there is just the two of us we never found a use for them......so they are as new and unused!
Post #566753 Fri Oct 12 2018 8:38am
B9BS X
Are these wireless or do you just plug them into the doors were the headphone jack goes? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #566806 Fri Oct 12 2018 8:34pm
rickshaw
They are wireless
Post #566824 Sat Oct 13 2018 8:31am
B9BS X
Do they take standard batteries? Also how do pair these up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #566869 Sat Oct 13 2018 7:30pm
rickshaw
Hi , they take standard AAA batteries (x2)
Sorry, can't help in advising how you pair them or use them as I never even tried to use them in my Sport!!
Like I mentioned before my Sport was fitted with the Hybrid Dual View TV as standard but it did not have Rear Seat Entertainment fitted.
Hopefully another Forum member may be able to offer advice???
Post #566896 Sun Oct 14 2018 9:11am
Not sure you can unless you have the wireless headphone transmitter fitted in the roof, all I can see on my headphones are a power button, volume control and channel selector.
Digital Wireless Headphones
The Infrared Headphones Transmitter is located in the roof headlining near the interior lighting console assembly.
The system can support up to three pairs of wireless headphones. When dual-view screen is fitted, the front
passenger can listen to TV/DVD and when RSE is fitted, rear passengers can listen to selected source on RSE screen.
The headphones have an adjustable headband which operates on a ratchet mechanism.
The headphones house the infra-red receiver sensors which receive the transmitted signals from the headphone
transmitter, two AAA batteries located below a sliding cover and the power on/off switch. When inserting the
batteries it is important that the battery polarity is observed as marked in the battery compartment.
The RH side of the headphone houses the volume control, a channel switch and a power 'ON' LED (light emitting
diode). The channel switch allows the user to select alternative audio channels (rear left/right, dual-view audio
source) when active. The power 'ON' LED is illuminated when the on/off switch on the RH side of headphone is
pressed. This will remain on and the headphones powered until the switch is pressed for a second time. If the
headphones have not received an infra-red signal from the transmitter for several minutes, they will automatically
switch off to prevent battery drain.
Post #566901 Sun Oct 14 2018 9:54am
rickshaw
Thank you Col - I appreciate you adding the info.
Hope this clarifies things for B9BS X !!
Post #566934 Sun Oct 14 2018 1:42pm
rickshaw
Price of headphones reduced to £20 each including UK postage.
Post #567668 Fri Oct 26 2018 8:37am
