Home > General > Torque converter refurb recommendations needed |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
I got the replacement torque converter from Bristol transmission highly recommended on the D3 site and had no problems don’t forget to get the filter changed while the box is out.
Tue Oct 09 2018 10:16pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8841 |
I had my TDV8 TC done at Bristol Transmissions at 119k miles. Ended up being a refurbed box as the output shaft splines were worn. You have to take everything out to get the output spline out and they said they wouldn't do it unless I agreed to a refurb. That, or they'd just change the TC and I could take my chances with the splines. I got the box refurbed as it seemed sensible to me. They also did the input spline for the transfer box as that was also worn. Included a new transfer box drive chain in the process. Box still going well when I sold it at 174k. 2012 SDV6 - it's missing a couple of cylinders
Wed Oct 10 2018 5:29pm |
If you would like to avoid the long slog to Bristol then I can recommend Stephens Engineering near Hertford : https://www.stephensengineering.co.uk
Wed Oct 10 2018 7:31pm |
Flatteraxe Member Since: 23 Apr 2014 Location: Leicester Posts: 43 |
Thanks for the replies.
Wed Oct 10 2018 9:50pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
There is a place just south of Royston which isn't too far. Experts on landrover etc trans. Howe engineering. |
Sat Oct 13 2018 6:40am |
