Home > Technical > Anyone help with suspension fault please? |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Can you post up fault codes?
Sat Oct 06 2018 8:26am |
Toddy Member Since: 05 Oct 2018 Location: Cumbria Posts: 8 |
Thank you for the reply. Only fault I know is the garage has said ECU, so no codes sorry. I did see them put the diagnostics on it when I went to collect it the first time, and did see them try to clear the codes and only bit I could see on the screen said something along the line of "unable to clear".
Sat Oct 06 2018 8:37am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
They can't clear the fault code or codes because they haven't cured the fault. Leaves a lot of scope for them to just say ECU fault, without fault codes very difficult to advise as there are a awful lot of different codes go with the eas.
Sat Oct 06 2018 8:45am |
It’s only a suspicion but the ECU fault maybe down to the suspension fault. The ECU may restrict to 30mph due to the suspension fault but may not be directly faulty. There are some good Techies on the site who im sure will come along but I would think the garage don’t have the kit or knowledge to sort this.
Sat Oct 06 2018 8:49am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
after a calibration on an IID, you need to re-enable the system, otherwise the red light stays on |
Sat Oct 06 2018 10:38am |
Thanks everyone for their replies. I have left the car at the garage to sort it out, but from the replies I am wondering if it is best to take it to LR, used to have it serviced at Coniston LR, unless anyone can offer any alternatives even if I have to drive there at 30 mph all the way!
Sat Oct 06 2018 8:21pm |
I think you may find being unable to lower or raise the suspension is a sort of default mode if there is a problem, I would have though the only way to clear the warning is fix the fault.
Sat Oct 06 2018 10:11pm |
After a calibration yes.
It does sound like in needs re-enabling. Their system should do it. It's difficult to tell from your post though, and the fact its been to the garage twice for them to do things and making it worse |
Sun Oct 07 2018 10:07am |
Thanks again for your replies, proving helpful as it gives me more information to try and make a decision as what to do next.
Sun Oct 07 2018 5:16pm |
It’s probably a wording issue here. I doubt it says ‘Not to calibrate’ but more ‘Could not calibrate’ meaning there is still something to resolve and therefor it is not possible to calibrate. 2012 5.0 SC AB
Sun Oct 07 2018 5:20pm |
duplicate post due to the crap Sky Router! 2012 5.0 SC AB
Sun Oct 07 2018 5:21pm |
Thanks Brit Plumber, that is a very good point and a question I will ask first thing in the morning when I speak to the garage. Although if it is could not calibrate that does dispel my thought that recalibration may be all it needs!! |
Sun Oct 07 2018 5:24pm |
Not necessarily, it could be the way they are doing it or the measurements they are entering are outside of parameters. If they use the default values for a Range Rover rather than a sport for example. 2012 5.0 SC AB
Sun Oct 07 2018 5:29pm |
Once again thanks for the quick reply that helps explain further, I will ask for more info on exactly why the calibration didn't happen on Friday, in the morning.
Sun Oct 07 2018 5:37pm |
