Home > General (L494) > Surround view distorted |
MrM Member Since: 16 Jan 2016 Location: London Posts: 146 |
Surround view is afterall a montage of images from the various cameras around the car; there is no camera 40ft above the car looking down, so some distortion is to be expected I guess.. It’s a little hard to see from the picture, I assume you are referring to the imagery to the front of the car? In truth, I don’t think mine looks an awful lot different to that.... |
Fri Oct 05 2018 8:27am |
Arkenbout Member Since: 04 Oct 2018 Location: Stockholm Posts: 2 |
Well, if you look at the white stripes on each side of the car, you'll see 1 in front, completely on the wrong spot. Almost like the camera is turned 90 degrees and the computer tries to make something out of it. And the grey pieces on each corner shouldn't be there either, it wasn't on my old Sport, and it wasn't on the courtesy Velar, see attached picture.
Fri Oct 05 2018 10:27am |
AHSFCA Member Since: 09 Mar 2011 Location: San Francisco Posts: 78 |
Mine is also distorted. I asked my dealer to take a look while my SVR was in for something else and they said they couldn't see anything wrong, or it was working "as designed" or something like that. Which would be very weird if so because I had a Velar before this one and the overhead image was perfect, without the solid corners in the image. I have a feeling they saw the issue but have no idea how to fix it.
Sat Oct 06 2018 6:06am |
