Home > General > Subwoofer |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4840 |
Inside rear tailgate. Have been a few posts about issues with them recently.
Tue Oct 02 2018 9:52pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4787 |
They aren't great! It's probably working as designed!
Tue Oct 02 2018 10:06pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
It isn't the greatest, but then it isn't intended to be a pimp my ride 15 inch blow your windows out job in the first place. There are limitations based around the physical location of it in the tailgate, so the relatively small size (I think around 8 inch) and the small cavity plus absence of dampening material all conspire against it.
Wed Oct 03 2018 10:27am |
Graham Ives Member Since: 04 Aug 2013 Location: Lincolnshire Posts: 74 |
Thanks guys did the slider across makes no odds minus or positive Rrs sport 2012 Orkney grey |
Wed Oct 03 2018 9:01pm |
Put your ear to the tailgate trim inside.
Wed Oct 03 2018 9:32pm |
You must have a loose connection then or your system is . There is no need to stick your head next to the driver if it is working, assuming you have normal hearing. |
Wed Oct 03 2018 9:49pm |
