Home > Maintenance & Modifications > brake pad warning |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Did whoever changed them fit new sensor wires.?
Tue Oct 02 2018 5:44pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 916 |
First port of call would be the cable/ sensor that attaches to the brake pad,,, we're they replaced when the pads were done?? 2010 RRS, TDV8
Tue Oct 02 2018 5:45pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
Or it could be the rear pads are low and the fronts are fine. They have a sensor on the front, (FNS from memory if it's the same as D3) and one on rear. They work by the disc wearing the pad down to where the sensor is, and contact with the disc breaks the circuit. Could the flickering being the intermittent contact with the disc? |
Tue Oct 02 2018 7:37pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
Both front and back pads were changed and also new sensors so perhaps one is faulty, the warning comes up on start up flickers for a bit then disappears . Think I will run it back to the garage today , thank you for the info guys |
Wed Oct 03 2018 6:26am |
I think you're absolutely correct, they've done the work, its not right, it's down to them to sort it out. Good luck |
Wed Oct 03 2018 7:34am |
