Home > Technical > CFF edit fails |
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 |
Hi all been trying to edit my cff file but the edits fail every time and I get a load of faults flash up on the dash, turn the ignition off then back on faults clear but no edits implemented. 2005 RRS 2.7 HSE. is this normal.
Mon Oct 01 2018 6:43pm |
reading was 11.9v on the dash which it's always done batteries only about 5 months old Bosch If it ain't broken down it soon will
Mon Oct 01 2018 7:07pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Just thinking that the GAP unit will abort the change if battery is low.
Mon Oct 01 2018 7:16pm |
Could be that spent all day sorting a load of electrical gremlins so battery might have been a bit low. will give it another go tomorrow. If it ain't broken down it soon will
Mon Oct 01 2018 9:07pm |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
do the ccf edits whilst the engine is running.... |
Tue Oct 02 2018 7:45am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
have you actually tried that ? |
Tue Oct 02 2018 11:01am |
Tried that but tells you to switch engine off. Anyway had another go voltage in green 12.5v.
Tue Oct 02 2018 12:27pm |
i'm surprised that it tells you to switch the engine off, never happened to me... |
Tue Oct 02 2018 12:44pm |
out of interest, what has enabling DRLs done ?
Tue Oct 02 2018 7:24pm |
I have it set to Scandinavian if light switch is either off or auto when you start the engine the side head and tail lights come on but if you switch to side lights or head lights they behave as normal. Weird that I can edit other functions but not the parking brake options If it ain't broken down it soon will
Tue Oct 02 2018 8:20pm |
Oh daytime lights. I see |
Tue Oct 02 2018 9:05pm |
