Home > Technical > Oil Leak noticed - any help appreciated |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
looks like diff drain plug,
Sat Sep 29 2018 4:50pm |
Sgwarnog Member Since: 29 Sep 2018 Location: Wales Posts: 6 |
Hi
Sat Sep 29 2018 5:03pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 454 |
Hi,
Sat Sep 29 2018 5:25pm |
Thanks for the info scrumps - I get it now!
Sat Sep 29 2018 5:58pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Have you had any work done recently? 2012 5.0 SC AB
Sat Sep 29 2018 6:15pm |
Serviced a few weeks ago.....
Sat Sep 29 2018 9:18pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Don't go overboard tightening it. If you're competent then you'll know how easily the steel thread will strip it's surroundings in that housing.
Sat Sep 29 2018 9:21pm |
If there still oil dripping in the mornibg I’ll take it in this week.
Sat Sep 29 2018 9:42pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
The plug has lock tight on it when you buy it, you can see a trace of white on the thread in the picture. The torque setting is 28nm so if you have a low range torque wrench you could see if it’s tight enough. It doesn’t go all the way in some thread will still show when tight.
Sat Sep 29 2018 9:44pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
I don't know if it's just the angle of the photo, but it doesn't look square to the thread, almost as if it was cross-threaded. This could explain why it's tight but still leaking. Did you have the diff oil changed? |
Sat Sep 29 2018 9:49pm |
Best to take it back if it’s just been a serviced |
Sat Sep 29 2018 10:14pm |
Update:
Mon Oct 01 2018 3:59pm |
