Home > In Car Electronics > HDD help on 2010 Model |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 |
I have the same year and spec and my car doesn't have the upload feature on it, I think this occurred on late 2011 and up models when they went to the 8 speed gearbox. The sat nav is loaded in the RRS system and the only way to update is by visiting a JLR garage. There are lots of posts on this side of things as it is expensive and the maps are not up to date. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Fri Sep 28 2018 7:58pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
The sat nav is a pain but although this won't help you they changed it for 2012 MY so I recently updated mine to the latest (had been running original so was missing a chunk of the M74 for example) via usb stick. 90 quid off ebay. |
Sat Sep 29 2018 6:03am |
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 |
Thanks for the replies. At least I know it is not meant to be there rather than a technical fault for not being there. 2010 3.0 TDV6 RRS Overfinch GTS
Sat Sep 29 2018 8:31am |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 465 |
Any chance of a link to the USB Stick you obtained?? |
Sat Sep 29 2018 10:40pm |
