Home > General > Battery file for parking up |
If you are worried then a cheap solar panel that has a lead long enough to get to the jump start posts under the bonnet will trickle charge it fine. Make sure you get one with a blocking diode so you don’t turn the solar panel into a consumer in the night time though! I put a post up last year about how to rig the lead invisibly through the driver’s door jam and into the engine bay. In L494’s the battery is in the boot which is why you need to use the jump start posts under the bonnet.
Tue Sep 25 2018 8:46pm |
