Home > Maintenance & Modifications > Rock crawl
HughN
Wales
Rock crawl
I have this 'thing' where every so often I put the terrain response into Rock Crawl (but not drive anywhere). My thinking is that it checks low ratio can be engaged and the diffs lock, i.e., no dormant failures.
Am I being paranoid or sensible? My wife thinks I'm more likely to wear it out and cause a problem!
Post #565009 Tue Sep 11 2018 1:08pm
no, I do the same. I also engage low range on my Defender every so often.
it's good to have the systems work themselves every now and then Thumbs Up --
Post #565012 Tue Sep 11 2018 1:16pm
Engage low range and drive it forwards and back about 30 yards. Sticking it in rock crawl will usually lock the centre diff too. That's everything moved.
Engaging low range and driving it back and fore is part of the service - but I bet it never gets done.
Of course, the best thing is to take the vehicle off road now and then and give it a proper bit of use! No point worrying about whether things work if you never use them anyway. Whistle Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #565021 Tue Sep 11 2018 2:46pm
Brit Plumber
I also go through the full range every so often just to excercise everything. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #565046 Wed Sep 12 2018 12:21am
