Home > General > Tailgate warning
M42
Tailgate warning
Could anyone advise me how to stop warning on dash 'tailgate open' when tailgate is closed? Can't seem to find a sensor or switch! Both Tailgate functions open and close but can't get rid of warning on dash, any advise appreciated
Post #564927 Mon Sep 10 2018 3:05pm
PompeyDave
I have this problem intermittently too. Is it a known faulty switch issue anyone please?
Post #570043 Wed Nov 28 2018 10:29pm
Tim in Scotland
It may a faulty switch but is it the upper section or the lower that is causing the alarm? It isn’t unknown for the upper section to fill with rain water spray and condensation if the rubber opening handle cover gets perished. On the lower/main tailgate section check the contacts aren’t worn or dirty. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #570054 Thu Nov 29 2018 1:19am
PompeyDave
Thanks- Yep, I’ll do both the bonnet and tailgate sensors I think as they’re both showing ‘open’ on the dash quite often since the winter weather arrived.
Post #570066 Thu Nov 29 2018 9:41am
Tim in Scotland
The bonnet sensor replacement has been covered here several times so a search should find it. The upper tailgate rubber switch cover perishes after a few years so you may need to purchase a replacement. When it failed on my both my L320’s it was replaced under warranty with a whole new upper tailgate section as it wasn’t just the switch that stopped working, the dealers found the upper plastic section half full if dirty water and all the wiring loom corroded and needing replacement, so that rubber cover needs to be watched for degradation. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #570070 Thu Nov 29 2018 10:06am
PompeyDave
Ok cheers, I’ll check both and report back.
Post #570073 Thu Nov 29 2018 11:04am
M42
thanks, will check and replace as necessary, thanks again for your help
Post #570923 Tue Dec 11 2018 6:54pm
PompeyDave
Ok, got the grille off and found the bonnet switch covered in greasy dirt. Once cleaned it looks like new so hopefully no more late night alarms- it went off at 00:20 last night Sad .
Post #570938 Tue Dec 11 2018 8:37pm
