Home > My Range Rover Sport > How much tread ? |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 |
Okay admit my ignorance here - but how much tread is there on a new tyre ?
Wed Jan 31 2007 5:41pm |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
7 - 8mm i believe new
Wed Jan 31 2007 5:53pm |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 |
I would of thought 8mm if you are on 19" |
Wed Jan 31 2007 6:09pm |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
Hmm, that doesn't seem too bad really? 2mm in 6.5k.., that means you're going to get around 20,000m from a set of rubber on a big helfty 4x4. Could be a whole lot worse? |
Wed Jan 31 2007 6:29pm |
So therefore not too bad so far ?
Wed Jan 31 2007 10:45pm |
Legal limit is 1.6mm not that you would want to get down to that |
Wed Jan 31 2007 11:24pm |
Well, if a tyre starts with 7.5-8.0mm tread, then you've used an average of either 1.5mm or 2mm. So, the remaining 4mm+ of tread represents slightly more than 2/3 of your tyre life. With just less than a third gone after 6400m, 20,000m looks a likely distance they'll go before you hit the 1.6mm replacement limit that Cliff correctly stated. Having said that, I think you'll find most experts would recommend replacing tyres well before 1.6mm as the road-holding quality and wet characteristices will have significantly diminished. Phew, that's enough maths for one day thanks! Last edited by Brian Mason on Wed Jan 31 2007 11:42pm. Edited 1 time in total |
Wed Jan 31 2007 11:40pm |
dah......
Wed Jan 31 2007 11:42pm |
Dutch_Mud Member Since: 09 Mar 2007 Location: noord-brabant Posts: 4 |
I have driven 30k and still had 4 mm on my previus super charged 275/40/20 - but they shoot you when you drive over 70 in holland Range Rover Sport TD V8 2007 "first edition"
Fri Mar 09 2007 10:37pm |
