Home > Technical > ELECTRICAL GREMLINS (AGAIN) 2010 sport hse v6 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
The clock spring's are known to play up occasionally as are the small wiring harnesses in the steering wheel, harness is only about £20.00 but there are two of them both the same item though, one for L/H switch pack and one for the R/H might be worth a try first as not to expensive, only thing is the phone controls are in the R/H switch, radio controls L/H switch. Could try and get codes read as might show something.
Sat Aug 25 2018 4:35am |
