Home > General (L494) > Another Air Con,Issue!
jimbg
the_big_1 wrote:
I have emailed the dealer stating that's the original fault (that appeared after a service) has come back after about 4 weeks. They also stated they had put dye in.
It's weird as it started to play up with the drivers side vents blowing warm and passenger side freezing cold.
Wasn't sure if there was something else that could cause this fault
How old is your car? There was a HVAC update for this exact problem. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #563639 Mon Aug 20 2018 8:44pm
Welshian
Wales
Mine is a 63 plate. RRS2 HSE Chile Red
1955 Morris Minor lovingly fitted every nut and bolt
Post #563642 Mon Aug 20 2018 8:53pm
jimbg
If you are getting hot from one side and cold from the other then probably worth checking it out. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #563644 Mon Aug 20 2018 9:03pm
