Home > Technical > Dab |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4816 |
I think will find the DAB antenna is part of the roof mounted GPS aerial, it is not part of front windscreen if that is what you meant. The FM aerial is part of the N/S quarter light glass I believe and the TV one is in the O/S glass on a facelift car.
Mon Aug 20 2018 9:09pm |
Hi Col no I just wondered if it could be retrofitted to a 2005 sport |
Mon Aug 20 2018 9:37pm |
Can't really answer that I'm afraid, but looking at the wiring diagram it's almost looks like a stand alone system, with a live power feed and a feed in and out from the MOST circuit into the module, plus some coax type leads out to a amplifier and aerial and a couple of earths. Sounds quite simple really might be able to pick up the bits and pieces wiring etc. from a breaker. As have said before not auto electrician or audio engineer so unable to say one way or the other really. If you pm me a email address I can send pdf file of wiring so you can see for yourself which may help.
Mon Aug 20 2018 10:06pm |
