Home > Maintenance & Modifications > Weeping brembo..
Themoog
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
Weeping brembo..
I noticed the other day that the inner bleed screw on the drive side caliper is dribbling a bit. Has anyone had this and fixed it?
I read somewhere that it is common on Brembo calipers on motorcycles and they put ptfe tape around the thread as that's where the weeping is from. Thoughts..
Post #563286 Wed Aug 15 2018 6:36pm
Brit Plumber
That sounds odd as leeking fluid should come out of the hole in the nipple before it comes from the thread. That is unless the Brembo bleed nipple is different to normal. Is the nipple tight? Is it visibly damaged? 2012MY RRS 5.0 Supercharged Autobiography (Current)
67 plate Focus ST Line (Current)
09 Mondeo 2.2 Titanium X Sport (Current)
02 Ford Focus TDCI (Brilliant car sadly scrapped)
99 BMW M3GTII (Amazing car, written off By a Fiat)
Post #563295 Wed Aug 15 2018 9:29pm
Themoog
Seems tight and doesn't look damaged. I think it actually may be leaking through the hole as it's popped the dust cap off. Perhaps there is something stopping it seating correctly.
Post #563299 Wed Aug 15 2018 9:58pm
Brembo recommend tightening to a torque of 19Nm on the bleed nipples, might be worth checking, otherwise could be worn taper/damaged seat on the nipple or caliper, but wouldn't really think it would be the caliper seat.
Post #563300 Wed Aug 15 2018 10:06pm
Brit Plumber
I’d be tempted to slightly loosen the nipple and retorque. If it still leeks, replace with a new stainless nipple (seen on eBay specific to the RR Brembo) and bleed your brake. 2012MY RRS 5.0 Supercharged Autobiography (Current)
Post #563319 Thu Aug 16 2018 7:44am
