Home > Technical > Sensor/ blank connector query |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4840 |
If the wires are black and red with green tracer I think it will be for the transit relay which is removed before delivery and not used, hence why it is blanked off, not quite sure where it is secured, thought it was taped to positive battery lead. Alternatively if the wires are black and red with a black tracer it maybe for a change over valve used in the FBH water circuit which may or may not be fitted, I think it depends on the vehicle market. Unfortunately as I have a S/C which do not have the FBH fitted I can't tell you where that should be clipped either.
Wed Aug 08 2018 12:20am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
spare connector.
Wed Aug 08 2018 12:21pm |
Remembered this previous post from a while ago. I think the reference number of the plug itself is C2034, C0926 is the FBH connector.
Wed Aug 08 2018 12:32pm |
rocky4x4 Member Since: 02 Jan 2009 Location: West Yorkshire Posts: 3 |
I ‘ve been on holiday so apologies for the lack of acknowledgement.Many thanks for all the replies and the link which answers my question perfectly.Never noticed the connector until I got the vehicle back after a cam belt replacement and gearbox flush so presume it was disturbed at some point and left loose. First RRS I have owned and very grateful for the info available on the forum |
Fri Sep 07 2018 10:47pm |
