Home > Technical > Damaged Locking Wheel Nut
i_dinler
I damaged my locking wheel nut on MY14 RRS, as it just spinniing.
Any Recommendations?
Post #562168 Fri Jul 27 2018 9:25pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
If you can’t get it off yourself any decent garage will for a small consideration.
Then, get the other 3 off and throw them away and replace with ordinary wheel nuts.
Wheeltheft was a 70 - 80s crime. Now they nick the whole car.
Post #562169 Fri Jul 27 2018 9:49pm
Do you mean the actual wheel nut or the key for removing them?
Post #562172 Fri Jul 27 2018 10:08pm
i_dinler
Ohh my bad. I meant the key. Its just spinning.
Post #562173 Fri Jul 27 2018 10:27pm
i_dinler
I got the Autobiography 22” Wheels so prefer to keep the locking wheel nuts, I’m hoping to get a replacement key. 🤞
Post #562174 Fri Jul 27 2018 10:30pm
Have a look at the key, should be a letter stamped on it i.e A, B, C etc. 20 different letters in all, just order key with same letter from dealer. Quite often happens if some clown uses a windy gun on the key.
Post #562175 Fri Jul 27 2018 10:33pm
i_dinler
Yeap got the letter and will phone the dealers tomorrow. Cheers Col
I actually managed to damaged it whilst tightening the nut manually after changing my rear brakepads. So cant start the front pad job until I get my key sorted. 🙁
Post #562177 Fri Jul 27 2018 10:34pm
Sorry, didn't mean to imply you were personally a clown, mainly referring to one at Crapstone Landrover Aylesbury, who did it my own car, ended up going to another dealer to get all wheel nuts loosened as they were well overtightened after a service.
Post #562178 Fri Jul 27 2018 10:47pm
i_dinler
No offence was taken pal. Thank you for your input.
Post #562179 Fri Jul 27 2018 10:52pm
